Old 08-25-2010, 11:49 PM
I think that set has some form of autoprogram button on it. When you press it, the TV will rapidly run through all the channels. Even at that, those sets weren't able to receive more than 42 channels on cable. That "110 channel" statement is sort of misleading as they add the 68 "air" channels to the 42 "cable" channels to get 110.
If the autoprogram does not work, the set likely has a bad tuner or tuner control problem (which I've seen on those). I've also seen shorted HOT's, bad flyback transformers, bad yokes, weak CRT's, power supply problems, loose connections, and vertical problems with these sets when they were just a few years old. About a year ago, I fixed two of these for a guy. One had a weak CRT and was full of bad solder connections and the other had a bad cap in the vertical circuit. Before that, it had been years since I'd worked on one. I'm telling you all of this so you don't spend too much time with it. Those sets did make a decent picture; but, they were not much to write home about as far as being reliable.
