Old 08-24-2010, 10:37 PM
That same cabinet was used with several chassis designs during the '70's and '80's. I've seen those sets that used the vertical chromacolor II chassis, the 1st generation 9-153 based system 3 chassis, the 2nd generation system 3 that used the 9-160, and the third generation system 3 that used the 9-186 HV module. The chromacolor II version was the best. The 1st generation system 3's of '78 still used a power transformer based chassis; but, they switched to an inline CRT and large printed circuit modules with those edge connectors that tended to give trouble. Also, the 9-153 HV module gave trouble in those sets. Then, we move to roughly '79-'82, the years that the 9-160 series sets were in production. This chassis eliminated the power transformer based power supply and the previous 9-153 HV module and replaced these parts with the 9-160 power supply/HV/horizontal sweep module. The rest of the modules and the inline CRT were similar to the first generation system 3 sets. The 9-160 modules had their fair share of problems; including loose connections, chain reactions that would fry many components on the board, and flybacks that would arc viiolently and sometimes catch on fire. Not to mention that there were too many heavy components attached to this module, which is probably why so many of them suffered from cracked and/or poorly soldered connections. From around '82-'86, the 3rd generation system 3 was in production. This set used a 9-181 main module and a 9-186 HV module. These sets had their own weird problems and a "dead set" could be a real PITA to fix. I've seen these sets where one module would fail and damage the other module (same goes for the 9-160 sets). Also, the inline CRT's that were used in the earlier system 3's didn't seem to last near as long as the delta gun tubes of the '70's. They weren't as bad as the '90's era tubes; but, they were still not up to snuff with the older '70's delta gun tubes. In my memory, I've not seen too many weak Zenith delta gun CRT's. The ones that were weak were still watchable and usually responded well to rejuvenation.
And, those curved Zenith TV's came with many different tuner configurations: manual single knob varactor, manual push button varactor, space command varactor, and space command digital cable ready tuning. I think the latest ones from the mid '80's even had stereo sound. Some of the late '70's-early '80's models had a picture zoom feature and/or a built in "space phone".
So, if I were to look for one of these, I'd hope to find a vertical chassis CCII version. The later sets produced a good picture; but, were not built as well and were not near as easy to troubleshoot.
