Old 07-25-2010, 12:39 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Wow!! Fantastic job
How did you cut out the panel ? It looks very clean and crisp.
I'm a little surprised how red that toner turned out. I'll keep that in mind for future projects.
The round holes were drilled with Forstner bits. The large opening and the square hole were cut with a scroll saw. I then made a jig with a rectangular opening and used a laminate trimmer in a router to clean up the square hole.
I then used the router on the table saw's router table to clean up the straight sections of the CRT bezel hole. I had to touch up a couple of places on the curved sections by hand with the router.
It did come out pretty red, but the red was accentuated in the outside photo because the sun was setting on the horizon.
John
Old 07-26-2010, 11:52 PM
jeyurkon's Avatar
Here are a couple of photos with it working. With just the room light the CRT shows up too bright. With a drop light it's kind of washed out. Guess I'll have to do the room light, no room light, Photoshop trick if I want a good photo.
I need to rotate the yoke a bit. Seems to have moved while carrying it out of the dungeon. I also didn't notice that I needed to center the horizontal before taking the photo. That's been fixed now.
It had good bass before mounting the speaker in the cabinet. Now it seems a bit excessive.
John
