Old 07-17-2010, 05:56 PM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
Ohhh yeah... so all I should really worry about is taking off is those magnet rings in the back and that ion trap and slide it out from the front?
Wow, I just got it out in no time. That was a lot more simple than it looked... thanks!
Old 07-17-2010, 09:38 PM
leadlike's Avatar
leadlike leadlike is offline
Do you have service info yet? I just picked up a stack of Rider's manuals today, and the complete service info on your set is here...
FWIW, I have a 10" tube with even bigger cracks on the neck. I put it into my dad's tv and he has been playing it nonstop for the last month or so-still runs good. I would at least use the old crt to set up your tv during restoration. Maybe hunt down a brightener if the picture is still dim after a recap...
Old 07-17-2010, 10:19 PM
VK Member
Yeah, I'm pretty sure this CRT will do well-enough for me to check for improvement after I replace the capacitors. If there's hope for it, even with the cracks, then I might not count it out just yet. It had a dim picture that whole time and when I saw the crack around the neck, I'd feared the worst.
Oh, and I haven't gotten ANY kind of service info, yet! The whole reason I was taking out my CRT today was to get into the chassis and make a lame attempt to find the values on the capacitors themselves. The cap's don't look melted like the one's in my radios, but all the same. But yeah, if you were able to get that service information to me somehow or another, I would definitely appreciate it!
Old 07-18-2010, 11:55 AM
leadlike's Avatar
Sounds good. Pm me your shipping info and I'll get a copy made for you. If it is a slow day at work tomorrow, I might get the chance to go over the parts list and be able to tell you what caps would need to leave that set.
Old 07-19-2010, 09:11 PM
VK Member
While I'm getting things sorted out, I thought I'd take a moment and talk about another interesting feature of my Zenith. It's probably not that uncommon for televisions of this vintage, but it's just something I had never seen before!
This never actually worked the few times that I did turn on my tv, but got the idea of how this worked using a LED light on my keychain. To make it project the numerals properly, I'll have to do some adjusting. It had a type 47 bulb in there, which seems to work when I power it with a 9-volt battery. I never saw it light while in the television, however.
I wonder why it displays the number "25" when turned to channel "13" ...
Old 07-19-2010, 09:59 PM
I could be wrong on this particular TV set, but usually there's a plastic cap of sorts that would cover the terminals on the yoke, and also hold the centering magnetic rings. But the plastic used does decay, so it's not surprising that it's missing here. And the ion trap is way too far back on the neck.
Old 07-19-2010, 11:57 PM
leadlike's Avatar
You're right-the back cap of the yoke has rotted away, but luckily the centering rings are still there-rattling loose around the ion trap. I don't know what the "25" numeral is about-does this set have a UHF function?
Also your tube has a really neat label on it-what does it say?
Old 07-23-2010, 06:18 PM
rojoknox rojoknox is offline
Greetings from FixitLand!
Now THAT is interesting! First thing I noticed in your picture is that the channel numbers aren't in numeric order; the same thing is done on my Zenith (K1846R "Stafford", chassis 19K20) which appears to be the previous year version of yours. But that ghost-like number is truly strange. Don't think my set has that feature. But it could be that your set, like mine, has a UHF "strip" in the tuner. On my set, it was installed in place of Channel 3 (so I don't have Channel 3 available!). Perhaps such a thing was done to your set? Very curious! I've gotta check my set a little closer...
Take care,
J. E. Knox 'The Victor Freak'
