Old 07-01-2010, 11:35 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Well, I guess the stains are still there, they just don't show up except when you take a photo. The same with the speaker cutout. I should have painted it a dark color, but it doesn't show up under diffuse lighting. I said the speaker was recessed 13". Not sure what I was drinking, it's more like 5-1/2".
I made corner molding out of mahogany using a 1/4" round-over bit with a router and table saw. I still need to varnish them and nail them in.
John
Old 07-03-2010, 11:47 PM
jeyurkon's Avatar
Finished molding
I put a finish on the molding and installed it. That's a little difficult since it's only 1/4" wide. I wasn't able to come up with a filler for the brads that match the finish very well.
The color of the grille cloth seems too light. In looking at the photo on the front of the Sams I'm not sure it was a diamond pattern.
I remember it being nearly black, my brother says it was dark brown with silver running though it.
AES has a black and a brown basket weave pattern for guitars that looks pretty close. I'll order some samples and see if I like it. If I do, I'll probably change the grille cloth.
Looks like my work was kind of clumsy on this one.
John
Old 07-24-2010, 11:10 PM
jeyurkon's Avatar
Finally, it looks like a console
I finally finished up the panel. I started by laminating ribbon cut mahogany paper backed veneer on to plywood. I veneered both sides to prevent it from bowing later. I used Heat Lock glue.
I then made a paper template.
After transferring the template I cut out the panel.
Then I checked the fit.
I then filled the grain by padding on six coats of orange shellac. Sanding it down to the wood with 180 grit sandpaper. Then repeated, but just sanding down almost to the wood. 180 grit is too coarse. I used it after reading a procedure on a woodworking site. I ended up using 600 grit for sanding between coats of Lacquer. I used Mohawk Classic Brown Mahogany.
The front after apply several coats of the toner lacquer and a couple of coats of clear satin.
And the back with clips installed.
In order to screw it in with wood screws as it was originally done I had to make a fixture for my drill press to angle the screws 30 degrees from the normal. I glued on cork so that it wouldn't affect the finish. I couldn't just free hand it because the panel sits behind strips that are only 3/16" thick and you don't want to risk having the screw hole show up.
It was either this or make a drill guide to hold in place inside of the cabinet and use a hand drill.
The fixture:
Here's the final product. I'll have to take some photos of it working. The bezel is NOS courtesy of rdreyfoos. It has a little shop rash on one corner, but I'm reluctant to try to repaint it at this time.
As I mentioned previously, I don't want to refinish the rest of the cabinet for sentimental reasons so I had to try to match the finish.
John
