I think some late CTC39's used a 25V tube.
Well, browsing ads and catalogs I noticed that RCA didn't use the same cabinets across different chassis. I did some hunting and found an ad from 1972 (I think) displaying that exact cabinet and control layout (no power bar, one button above the two pots in the door) - crossed the model number in the ad (GR670) through the Sams index and came up with the CTC39 chassis.
Wow I learn something new every day I guess. So I did have the early CTC-39.
Honey, turn on the tv.. I'm cold! |
Mark--did you say a muntz?You've gotta post a picture of that!!
Yep, a Muntz color set from 1965....be patient, I'll start a thread about it
I have a LOT of cabinet repair to do on it so it'll be interesting.
The 25V" set in the cabinet/control panel design shown here is used for the CTC-39 illustration in the RCA field service guide. The CTC-39 I have is in a metal table top cabinet with a 23V" tube and looks like a late model CTC-38.
Are you sure the set shown in this ad isn't a solid state model? I have a set which looks exactly like this at home which is an XL-100 solid state (CTC-46 or 48?) which I think is from 1973. The tube type CTC-39 set will say "AccuColor" above the volume/brightness controls but it looks like the text on this one is longer than "AccuColor" and may be "XL-100 Solid State" Here is a video of my solid state set: http://www.youtube.com/watch?v=6WUcNaYLA_c |
) and I replaced tubes, the horizontal output and damper IIRC. We ended up with it in the mid 80s. The VHF tuner didn't work, but UHF did work. Probably a dead VHF local oscillator tube. MY brother tossed it...
Cheers,
