Old 06-21-2010, 08:28 PM
I still need to pull the tuner/control panel, the tuner is just too flaky and I would hope that a cleaning will get me a more consistant pic. Also the VC is very noisey. I did replace the 6Z10 (audio detector/amp compactron) which did help the volume which was a bit low.
The AFC switch seems to have no effect what so ever, I assume it works like any other AFC to lock on to a signal.
The fine tuning control seems to have stopped working as well (afc off) it does not have any effect when pushed in and turned. I hope I did not strip anything with the frequent adjustments I was making, but at least it seems to have stopped on a good pic.
OR maybe the switch on the AFC is simply broken and its stuck in the AFC on. It was very balky. Anyway I will check into that when I get the tuner out for cleaning. That will also be the time I attempt to unstick the concentric UHF tuner.
