Glad you are having some success with that old set!! I expected it would be better with you---than in my storage garage.
I hope the tube is good....or at least it will "wake up" for you. I STILL don 't remember exactly where I got that tv. I THINK it was at an Estes auction--about 6 years ago or so. |
12VP4 test
I installed the 12VP4 in the 1-108 Chassis I have working. At first I thought the CRT was completely dead, but after turning the brightness up to maximum I was able to get a raster playing with the ion-trap magnet.
I let it play for awhile. The video shot looks better than it is because of the camera. It's barely visible in dim room light. The scan line splits into two lines as it crosses the center. It should just get wide. I need to move the focus magnet forward. I think the apparent split is because the center of the cathode is pretty used up. There is a pin point burn right in the center of the CRT where someone must have had HV, but no horizontal or vertical sweep. Or else it's just a defect. I could try baking the cathode at a higher voltage. Rejuvenating it with any other method is out. I don't think even the Beltron knows about this tube. So, do I send it to Scotty or modify the set to use a 12LP4 and keep this CRT as a collectible? John |
Looking at the dot pattern, I think that I am seeing a "hollow beam" that has less current in the center... perhaps the center of the cathode is "used up" or it may be ion damaged. I have seen cathodes where the coating in the center has been totally removed by ion bombardment, down to bare nickel.
If that is the case, It will not "wake up" with the application of 8 volts to the heater, but what have you got to loose by cooking it for a few hours? jr |
I tried a brightener. That did little. I then cooked it, but the Beltron manual suggested 10 volts so that's what I used. It made it almost watchable, but it faded after a few minutes of use. It's in a box and will be on its way to Scotty tomorrow. John |
So Scotty will have a new cathode installed in the old gun?... or does he have a supply of the triode guns?
jr |
The gun in the 12VP4 uses ceramic supports instead of glass. I wonder if this makes any difference in the difficulty of rebuilding it. John |
