And so it goes. However, I did not even stop to think that other television manufacturers were giving their sets model names well into the '80s. RCA's "Dimensia" line, Sony's "XBR" premium series of flat-panel HD televisions, etc. were these companies' attempts at doing the same thing Zenith and RCA had done for decades with model names for their TVs, but again, they are simply marketing symbols in the 21st century. Even RCA's "XL-100" feature name, which was coined in the early 1970s when that series of TVs was introduced, meant "eXtendedLife 100(percent solid state)" and actually meant something when the line was new (all-solid-state TV's were still in their infancy then), means nothing anymore today. My RCA CTC185 19" table set has "XL-100 Commercial SKIP" in white letters at the upper left-hand corner of the CRT mask, but I'm convinced that the label is just a carryover from the last days of the original XL-100 series since RCA does not use it on its new FP sets; probably stopped putting it on their CRT sets as well a few months before the end of the analog CRT era and about a year (more or less) before the DTV transition. In any event, XL-100 is no longer used on Thomson-built RCA FP televisions; it is probably just as well, as the name has outlived its usefulness--after all, all televisions made today by every manufacturer are 100 percent solid state, so RCA (Thomson) sets are by no means unique today--and haven't been for years. RCA could not have used this name, however, on some of its so-called "all-solid-state" sets of 1968-'69, as many of these sets still used a tube as the high voltage rectifier. That it is a one- or two-volt tube is beside the point. The point is that it is a vacuum tube, and any TV using such a tube in this position (even if the rest of the set is all-transistor) is definitely not all-solid-state. In fact, technically speaking, no pre-flat-panel solid-state TV is "all" (as in 100-percent) solid-state, due to the CRT. The term would make sense, however, when describing flat-panel televisions as these are completely solid-state, even down to the display, which these days uses (in RCA/Thomson sets anyway) energy-saving LEDs. I don't know if Panasonic uses these in its premium "Viera" line of flat panels, but it is a logical step beyond plasma and LCD displays, and would put Panasonic in direct (and, I believe, very fierce) competition with RCA/TTE as these are, to the best of my knowledge at this time, the only two well-built and reliable brands of flat-panels available today.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 06-26-2010 at 09:15 PM. |
