Old 05-28-2010, 06:51 PM
Rodzilla's Avatar
Rodzilla Rodzilla is offline
so i have the chassis "clean" or at least clean enough to work on,i have had a peak inside and scared myself[if you ask me,the greatest invention of the 20th century was not the automobile or the computer...but the printed circuit board!...yikes ]
i plan to make a parts run in the morning...but am stuck trying to figure what i need to get with regards to the rectifier...i just keep reading stuff that doesn't really apply to what i need to do or contradicts other stuff i just read..so before i bust out my DMM and just measure the output voltage of the selenium feeding the B+...can someone tell me what i need to do to figure out what size resistor i need to install to use a silicon replacement??...is there an accepted rule of thumb that works for this?
i have just read on another board that i may not even HAVE to use a resistor at all,but just slap the diode in it's place since the filament supply is not taken from the rectifier and won't be affected..and the overall difference in B+ voltage will not be large enough to bother correcting[+/-20% tolerance]does THAT make sense?...it's been a while since i learned any of this basic electrical theory and i just need a simple answer...what do i gotta do here?
Old 05-29-2010, 12:13 AM
I've never heard of that before. If you just put the silicon diode in without the dropping resistor, it could work well, or you could see too much voltage at the output of the rectifier--which could and likely will damage other parts of the radio. If you have a schematic, look at the value it gives for the voltage at the rectifier output. This is the value that must be at the output of the rectifier as measured by a DMM or DVM. The reason a dropping resistor must be used with a silicon diode rectifier is that the output from a silicon diode is somewhat higher than that from a selenium rectifier.
As to calculating the value of the dropping resistor, use Ohm's law: R=E/I, where R is the value of the resistor, E is the voltage at the output of the silicon rectifier, and I is the circuit current. This formula is all you need to know to find the right value for the dropping resistor. I'd just ignore all the other irrelevant and/or contradictory information you seem to have read; it seems to me that it will probably just lead you up a blind alley or, worse, down the wrong road.
