Old 05-27-2010, 12:15 AM
Headscratcher on the Bay
Ok, this neat old 10" Westinghouse showed up on the bay... Perhaps it has a somewhat optimistic starting bid, but I have never seen one of these in the flesh.
http://cgi.ebay.com/1949-Westinghous...49012872262581
The headscratcher part is that the set is shown displaying a bright vertical line... how can that be... usually if there is no horiz sweep, there is no HV. Oscillator HV supply? Mains HV supply? Yoke turned 90 degrees? What is happening with this set?
I am not associated with this auction,
Old 05-27-2010, 01:00 AM
I'm away from my books right now, but I have seen that screen associated with loss of horizontal sweep in troubleshooting examples. Definitely for oscillator type HV supply, perhaps others . . .
Phil Nelson
Old 05-27-2010, 02:57 PM
Josef's Avatar
Josef Josef is offline
Hi!
Vertical lines are not very common that is true. I guess it could be a shorted horizontal discharge capacitor or an opened deflection coil. If the set was stored in a basement with high humidity the seller had real luck that the HV transformer is still alive.
Everybody should know not to plug these sets in directly after they were found
Kind regards Josef
Old 05-27-2010, 03:18 PM
Adam's Avatar
Adam Adam is offline
Apparently, these old Westinghouse sets were known for this. "It was a common trouble that occurred in 20-year old Westinghouse TVs which had a separate high voltage supply. That way, even if you lost your horizontal oscillator, you still had high voltage." (quote from - "101 TV troubles from symptom to repair")
Old 05-27-2010, 06:42 PM
John Folsom's Avatar
That Westinghouse is a RF high voltage power supply set. Sams 99A-14. Rather uncommon is sets larger than 7".
John Folsom
Old 06-03-2010, 10:12 PM
mbates14 mbates14 is offline
and the thing is, nearly every "modern CRT RPTV" has the separate horiz/HV setup. But of course, there are saftey circuits that go hand in hand between the 2 circuits so if one drops out, they both drop out.
