Old 05-27-2010, 12:33 PM
while futzing with the set I noticed a pretty extreme reverse pin cushion (guess that it the way to describe it, the horz bends up on top and down on the bottom). 1st I checked the tube, checked ok on tube tester, and its new. Next I check the tube pin resistance mearurements to the sams, ok. I tried the pin cushion adj slug and was able to get some of it out but still there.
Its like it just runs out of adjustment ranges. The circuit controlling this has a pretty low parts count. I was next going to try checking to see if it has any plastic/paper caps still in it (the pin cushion circuit). Should prob try a tube substiution just to be sure about that as well.
