Old 05-19-2010, 08:14 AM
sampson159's Avatar
sampson159
a small wading pool is perfect.you dont have to fill it up all the way.enough water to submerge the safety glass only.i have used many methods.one effective was the use of wd 40 and a heat gun.spray it into a loose edge and watch it penetrate .use of the heat gun forces it to spread,loosening the glass.it speeds the progress tremendously.the hot wire,hammer and chisel,piano wire,etc.i think i have ran the gamut.the wading pool is the safest,but also the most time consuming!
