Old 05-17-2010, 02:45 PM
Originally Posted by freakaftr8 View Post
I remeber working on my CTC-17 and the wires were corroded from the terminal strip off that choke. Same as you are describing. I had full vertical collapse. Might be on to something. I had to create a new terminal strip and replace a few wires.
hope that does it..
I replaced the short wire off the choke, then wire brushed the heated solder on the term strip. there was another wire going off some where that was toasty, i cut off a short pieced, scrapped the oxidation off and was able to get a decent joint (I think). I may end up doing as you did and replace that other lead, I think it went off to the PW700 board, but I lost track of it.
