Old 05-16-2010, 11:15 PM
could not find the 100 ohm resistor.
Need some one to check the Pin 3 of the 6GF7 that is the cathode of the vert output. The resistors in the circuit do not match up with the value installed. I have a 330 where a 68 should be, the total resistance at the tube is 1.6k
It looks like the vert uses boosted voltage off the fly. There is a diode in there that did not reg on my diode checker, perhaps its just a HV diode that the DMM cant check. I tested the forward and reverse res 2 meg one way 2.7 meg the other, but that is in circuit.
