Your board looks good. On mine, I pulled the whole thing, replaced every single cap and resistor (which is excessive, I know) hooked it all back up, and powered it up. The set ran like new!
I probably would not have rejuvinated that tube-I typically set the heater voltage a little higher, about 8 volts, and then let the tester cook away at the tube for a few hours. The emission almost always goes up. Rejuvination is very hard on crts (on all but the most expensive testers, it is usually just a fat cap discharging itself into the crt gun) and in some cases will totally trash a perfectly fine crt. |
I restuffed my slender Ecap, just like to keep the lead dress as orig as possible.
It just looks messy. I may have to buy some different caps as I don't think these 3 will all fit inside the can. We'll see... Last edited by PredictaNoob; 05-14-2010 at 01:36 PM. |
I always get radials, beside cheaper they fit better. Nichecon make some very slim ones that make for an easy fit.
