Old 05-06-2010, 07:55 PM
sampson159's Avatar
sampson159
what color is the crt face?if slightly green,then your b/w should be slightly green to start.a little tweaking until you get it to your liking.i like mine very slightly blue.start out with red screen,then mix green in until the screen is uniformly yellowish green,then mix blue until gray appears.service line adjusting is what i use.this is a personal preference and with a ccII you should be able to get it on the money if the crt is good.actually with a zenith,even a bad crt will look good!
