Old 05-03-2010, 10:02 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
what were you using for a signal source?
Is there snow visible and audible, or only a raster?
If there is visible and audible snow but you simply can't get a station, check oscillator voltages. If there is nothing but a raster check RF amp voltages and IF stages.
Have you cleaned the tuner yet? often times this symptom can be caused by a filthy tuner.
Please don't start replacing parts until you've found the actual failure. Replacing caps in the tuner and IF stages may have you needing an alignment afterwords. You might also think about obtaining a sams and or schematic to help you troubleshoot.
Good luck.
Jordan
Old 05-03-2010, 10:18 AM
leonk leonk is offline
Thanks for the reply.. here are my answers:
I was trying to catch a station using UHF/VHF (here in Toronto, Canada, analog signal is still around. I wasn't seeing any snow or audible snow.. all there was on the screen was a solid white/gray raster. The strange thing is that I could actually see the line traces on the screen.
The schematics are in the manual (really tiny!) I'll try to follow them. What is an IF stage?
Thanks.
Old 05-03-2010, 10:58 AM
that last 7uf cap may be NP which would be a large cap even by todays standards
Old 05-03-2010, 09:39 PM
Sorry, but what is 'NP' ?
Old 05-03-2010, 09:56 PM
non polar just a regular film cap
Old 05-03-2010, 10:09 PM
maybe the tuner is not working. If you have a schematic and can find the input of the video amp, then I would try injecting a composite signal there.
you can just take the video out put jack from a dvd and use that (not the RF but the video lead). To be safe I would put a meter on the test point to make sure there is no high potential (I messed up and "thought" I had the input of the video amp, when in fact I had a B+, fried my DVD). this will tell you if the problem is before or after the IF/detector stage.
Not knowing the chassis you should make sure its not hot (one side connected to the mains) before attempting working on it to avoid any nasty shocks. back in the 60's there was a lot of ways of hurting yourself (not as many product liabliity lawyers I guess).
I use an isolation transformer on any set that does not have a power transformer, and even then you have to be careful. A motorola I worked on had a big transformer for the filaments but none for the B+, just a voltage doubler and a floating ground for the B-
Old 05-04-2010, 01:19 AM
Reminds me when I was a kid, the Admiral Bakelite B&W set we had in the bedroom developed a problem. My father asks "Did it have a raster?" and not understanding correctly what raster" meant (thought it meant a screen of random snow) I said "no". Turns out the set did have a blank raster, and my father complained what an idiot son he had... Well, he forgot that a ten year old kid might not know what "raster" meant...
