Old 04-19-2010, 10:55 AM
kx250rider's Avatar
REAL TVs have TUBES!
Originally Posted by jeyurkon View Post
I'd check R198, R231. And if you replaced C168 0.015 uF, make sure you used the right value, it's critical.
V124, 6AC7, is used as a variable reactance to control the horizontal frequency and if anything is wrong in that circuit it can cause a problem also.
YES! That's the tricky part of all early RCA sets. Although I didn't check the location numbers in the 630, the cap that sits across the horizontal oscillator coil should be a mica cap, and needs to be the exact value, and 5% tolerance if possible.
Charles
