Originally Posted by ChuckA
If everything else checks OK make sure you have filament voltage to the 6AL5 (V123). Chuck
In a similar vein, check the 6AC7 H. control tube to see if it's warm. The one in my set would come and go; turned out that a filament lead wire inside the tube pin was loose and resoldering it made it work reliably. I resoldered all the tube pins actually. Tried all kinds of imaginary fixes before finding the tube was cold!
Or just try another 6AC7 and make sure the tube socket contacts are good as well.
A great engineer told me once, "Look for the broken wire, not the third harmonic!"
Cliff
