ok back to this one.
Pulled the chassis, while I had it out I decided to clean the tuner, I noticed the gear the turns the little tuning slugs was stripped. I had a junked tuner so I was able to replace that gear. Cleaned the turret buttons with an eraser and them lubed them back up with some tuner cleaner/lube.
I am going to replace some more caps on the deflection board and on the damper tube. I scoped the grid of the vert osc last night and it def has a lot of Horz noise getting in there (when compared to the other set with the same chassis). Not sure exactly how its getting in, lead dress looks good. I am hoping by replacing the remaining caps I will just get lucky. Its just too darn hard pulling this chassis and PCB work is easy so I figured might as well. there are not a lot of cap anyway. I dont like the way the vert hold pot ground is shared with the horz hold pot but it works on the other set...
Anyway will get back on it tonight.
