Old 03-13-2010, 11:01 PM
kuisis's Avatar
kuisis kuisis is offline
AK Member
6 volt Radio?
Has anyone ever seen a radio that runs off of a six volt battery? A friend bought one and wondered if there was a way to convert it to 110? If anyone knows if this is possible I would like to know. I will try to get more info, I haven't seen the radio yet.
Thanks
Tom
Akai G77
Klipsch LSI, Heresy, Cornwalls, and Chorus I
2 McIntosh MC250 and MC2100
Juicy Music Peach, McIntosh MX-117
1954 and 1956 Khorns
Old 03-13-2010, 11:13 PM
holmesuser01's Avatar
I've rebuilt 6V car radios. You can build a power supply for it.
Old 03-14-2010, 11:24 AM
marty59's Avatar
marty59 marty59 is offline
Old farm radios were the more common battery types, before standardized electricity was getting out to rural areas. Plus, 6 volt car/truck batteries used to be the norm before the mid-late fifties..
Old 03-27-2010, 04:11 PM
rca2000's Avatar
rca2000 rca2000 is offline
They, have what is known as a "vibrator power supply". think of it as a Switching power supply, but with a vibrating relay in place of the switching transistors and oscillator. This is EXACTLY how they work. The 6 volts( or in a few cases--2 volts, I have a couple of old GE "lunch box" radios, model #250 IIRC, that use a single large 2 volt battery. That powers the filaments of the tubes and the vibrator supply--it then produces over 100 volts that is then used for the B+ supply. In a car radio the 6 or 12 volts does the same thing--the car voltage powers the filaments...the vibrator supply raises this to over 200 volts usually--for the tubes B+. The output of the vibrator transformer is then rectified by a tube OR another set of contacts on the vibrator itself, known as a "synchronous" vibrator.
To power by 120 volts, One needs to either simply supply the 6 or 12 volts to the radio from a power supply..( the easiest way...) OR replace the vibrator tranny with a 120 volt unit. I have seen this done before.
Old 03-27-2010, 08:35 PM
Somewhere, I've got a mid '30's 6V Silvertone radio. And, there were also 32 volt radios.
Old 03-27-2010, 09:07 PM
David Roper's Avatar
console lover
There are a number of ways to convert 6 volt radios to 110. In the old days it was routine for an Elmer to re-engineer the power supply and audio output stages from scratch to use AC set tubes in a re-purposed farm set. I prefer to keep a radio as original as possible. Last year I converted an interesting Setchell Carlson radio to AC power and did so maintaining its unique tube complement: 6D8, 6S7, 6T7, 19, 19, 19.
As you can see, one of the 19s is used as a rectifier. The other two needed pure DC for their filaments, so the easiest solution in this set's case was to keep all filaments DC.
The vibrator was eliminated and a couple of connections were moved, otherwise the original circuit was left entirely intact and the mod is at least theoretically reversible.
Old 03-27-2010, 09:11 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
There were also 12V tube car radios that didn't need a vibrator. They used tubes designed to use the space charge effect. I don't know if any farm radios were designed to use them, but you can easily build a radio that works at 6 volts.
There is some information at Space Charge Tubes
John
Old 03-27-2010, 11:46 PM
I've seen a few of those auto radios that used 12V tubes. The ones I saw used a transistorized audio output stage and tubes for the rest of the set. I think these were used from the late '50's up until the early '60's, when SS took over.
Old 03-28-2010, 12:57 AM
jeyurkon's Avatar
I think they all had to have a transistorized output stage in order to get enough volume. I forgot about that.
John
Old 03-28-2010, 11:04 AM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
I have a Stewart-Warner that took a different approach - it has a big honkin' external power supply that looks vaguely like a military ammo can (but it's not, it has S-W markings on the top).
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 04-01-2010, 10:46 PM
Randy Bassham's Avatar
Randy Bassham Randy Bassham is offline
AK Member
I have a Montgomery Ward Airline and a Zenith set that will play on 6 volts DC or 120 volt AC. Both have a switch on the back to change the power input. I've also got an Airline Movie dial 6 volt table radio and a Zenith tombstone. The 6 volt sets are not as common as the A-B pack farm sets but they show up fairly frequently in rural areas.
"proximo satis pro administratio"
KAØSCR
Old 04-02-2010, 12:59 PM
Chimes's Avatar
Chimes Chimes is offline
VK Member
Deleted
Old 04-04-2010, 07:40 PM
One problem with the 32-volt farm radios was that they had the same kind of plug at the end of the power cable as today's 110-volt appliances. This was not really a problem in the days of 32-volt radios (the late 1920s-'30s), however, as the power outlets in farm houses were the same type; the power to these outlets came from wind-powered generators (windmills) that also charged batteries, which supplied power when the wind died down at night or on calm days. The problem is that if someone has one of these 32-volt radios today, if the person did not know the radio was wired for 32 volts, he or she could plug the power cable into a 110-volt AC outlet......and ruin the radio in the blink of an eye, as soon as the set was turned on. I've never seen one of these radios burn up from overvoltage, but I bet it would make a display of sparks and exploding parts one wouldn't soon forget.
