Old 03-05-2010, 02:13 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Originally Posted by rojoknox View Post
My '52 Zenith K1846R has a Channel 27 strip instead of Channel 3.
Nowadays, Ch 3 is the most important spot on the dial for us! Too bad they didn't stick that 27 strip somewhere else. It's a good thing most all VCR/DVD machines, modulators, and satellite boxes, etc. give you a choice of using Ch 3 or 4.
Charlie Trahan
Old 03-05-2010, 03:26 PM
grimer's Avatar
grimer grimer is offline
Old 03-05-2010, 05:11 PM
Originally Posted by grimer View Post
I have the Sams,thanks for the offer.The pic on yours looks great now!
My set needs a flyback, the wires to the HV rectifier,and to the HO tube,were
ripped out when I received the set.I was able to dig them out,reattach them,
and reassemble with hot glue,and then a coat of varnish.The repair seemed to work for awhile,but now I can actually hear arcing sounds from the fly itself. Of course this will not stop me from finishing this set,this is the fun part to me, because once the set is working,it just gets stacked up with all the other working sets.
Pat
Ditto. As much as I like my old 10" B&W sets, I don't watch them often. Most of the fun to me is in bringing them back to life and cleaning them up real nice. Then I push them to the back and pull out another dead one to work on. I have a dozen sets waiting out on the back porch
Old 03-05-2010, 05:30 PM
Charlie's Avatar
On Land
I bet that statement can apply to many of us here!
Charlie Trahan
Old 03-05-2010, 08:13 PM
cwmoser's Avatar
cwmoser cwmoser is offline
Not here. 1950's vintage TV's are rare as $3 bills.
CW
Old 03-06-2010, 12:14 AM
I'm calling this project officially done. I even stuck a TV lamp on top
Old 03-06-2010, 12:39 AM
Is this a big drum tuner? It's likely those blanks could have strips installed for specifc UHF channels that were in your area... and they gave you provisions for two channels instead of just one.
I think it would be really cool to find an early set with a UHF channel strip installed. It's always possible to have one and not realize it. It would be easily overlooked. The tuner drum in my Zenith PH has a empty spot where one could easily be installed. The drum on my Bendix does not. Makes me wonder about the Sentinel 7" sets... there's an extra click in the tuner and it's not labeled on the bezel.
I think so, but it's under a metal RF shield and hard to get a good look at. Do you think a tuner designed for VHF could go up to UHF frequencies
Old 03-06-2010, 01:40 AM
David Roper's Avatar
console lover
Apparently the answer is yes based on my experience and I could kick myself now for not truly appreciating it: a 1951 Zenith porthole I once owned (a VK member has the same set as his avatar) picked up o.t.a. channel 35 in the channel 2 position. I bought it from an antiques merchant who claimed to have gotten it from a very elderly couple whose primary set it had been since new. That was in 1991. If true, the original owners sure had one ace TV technician at their disposal considering channel 35 didn't come on the air until the set was about 20 years old!
Old 03-06-2010, 03:31 AM
cwmoser's Avatar
That is a neat TV lamp. Like to find one to put on top of my 1950 Zenith Porthole TV.
Is it an antique or is it something that can be easily found today?
CW
Old 03-06-2010, 04:08 AM
Vintage TV lamps are so popular that they have a category all their own on eBay. I see 231 listed today.
http://collectibles.shop.ebay.com/TV...053%2C1404%2C1
Phil
Old 03-06-2010, 08:29 AM
cwmoser's Avatar
Phil
Well I be darn. Did not know.
Never heard of a TV lamp.
Even not knowing, they are still visually appealing.
I guess this shows that some designs are timeless.
CW
Old 03-06-2010, 09:45 AM
Charlie's Avatar
On Land
I have a Sentinel similar to yours... trying to remember... that shied isn't easily removed?
It would seem those UHF channel strips are specifically designed to work in the VHF tuner. The original tuner strips are usually numbered on the strip, so, follow the numbers as the drum turns. If you come across a number that doesn't fit in the sequence, then you've got one.
That's the truth!! They've got some crazy lamps out there, too!
Charlie Trahan
Old 03-06-2010, 04:34 PM
Some sets, particularly Zeniths, had turret tuners with removable channel strips which could be replaced by UHF strips. The latter would be inserted in place of unused VHF channels in a given area. For example, if your area had channels 2, 4, and seven, and a new UHF channel went on the air on channel 52, you could get a UHF strip tuned to that channel, insert it in an unused position in your TV tuner, and presto, you would now have reception of the new station (provided, of course, that you had the proper UHF antenna; in the days of UHF channel strips, this usually meant a good outside antenna, although if you were very close to the transmitter you could get by with a loop or an indoor UHF antenna).
The maximum number of UHF channel strips that could be installed in any TV tuner is theoretically 12, although in most areas that number was somewhat smaller, especially in New York and Los Angeles which already have seven VHF channels. In these cities, a maximum of five UHF strips could be installed in the tuner, in place of unused channels 3, 6, 8, 10 and 12. In most metropolitan areas, however, there are far fewer VHF stations, so the number of UHF strips that could be installed in the tuner could be as great as nine or 10, although I doubt if any major US city (with the possible exception of Los Angeles) has anywhere near that many UHF stations. In my area near Cleveland, there are only three VHF stations on channels 3, 5 and 8, which leaves nine unused positions. However, there are (never have been) nearly that many UHF stations in this area; before digital, we had UHF channels 25, 43, 55, and 61. When UHF channel strips were popular, Cleveland only had one such station (PBS, then NET affiliate WVIZ) on channel 25, so only one strip would be required, and in fact the MATV (master antenna TV) distribution system at the local elementary school in my old neighborhood downconverted that station to channel 4, so no strips were required or used in those sets to receive the station; as a matter of fact, our TVs were all RCAs which I don't think could have been used with UHF strips.
I think the idea of using UHF channel strips to receive such stations on unused VHF channel positions was patented by Zenith early on, and could not have been used by RCA or any other TV manufacturer without risking a patent infringement suit--or worse. However, there is a way set owners could set up their turret VHF tuners to receive only the local VHF stations in their area--by removing all strips occupying unused channel positions, leaving only the strips for the active stations in the area. This would allow the viewer to switch from one local station to another without going through unused channels, and would also allow the use of UHF strips in the unused positions. Using my area as an example, grouping channels 3, 5 and eight together would leave nine unused channel positions, in which UHF strips for channels 25, 43 and 61 could be installed (further reducing the number of usused channels to six). This would afford the viewer the convenience (especially when tuning by remote control) of tuning to his or her desired station without having to flip through unused channels 2, 4, 6, 7, 9, 10, 11, 12 and 13, as is possible with today's electronic tuners which have an add/delete option for setting desired vs. undesired channels in a customizable scan list. The unused VHF strips could and should be saved in case the set owner moves to an area with different channels; of course, this would mean getting new UHF strips for the different UHF stations in the new area.
Needless to say, however, this is an outdated method of setting a TV tuner for receiving only the area's active channels in this day and age of electronic tuners. It cannot be used with older sets nowadays anyway, as older sets used with ATSC->NTSC converter boxes require that the VHF tuner be set to channel 3 or 4 and left there, all tuning (and presumably on-off power switching of the TV, not to mention volume control and muting) being done either at the box or via its remote.
Old 03-06-2010, 05:31 PM
I grew up in an area that only had UHF at first, and would say that they sorta worked. Strips were not recommended for fringe reception. Although the strip had tuned circuits for the UHF channel, gain must have been very low. I believe the oscillator was run at a sub-harmonic of the desired frequency and then multiplied by components contained on the strip. At the time, continuous UHF tuners seemed to work better than the Standard Coil tuner strips. Few had RF amp circuits, but some UHF band boosters were available. Poor converters and low power transmitters made for a fairly poor television debut, but what the heck...it was TELEVISION!!!
Old 03-06-2010, 06:06 PM
I have a Sentinel similar to yours... trying to remember... that shied isn't easily removed?...
Maybe, but I gotta pull the whole chassis first and my next project is already up on the workbench. I'll take a look one of these days and let you know what I find.
There's a whole website devoted to them: http://www.tvlamps.net/
What a collection!
