I don't know if you can hear station CFZM "Zoomer Radio" AM 740 in Chalmette but if you can, it will sound great on your Zenith radio. This is one of the few AM music stations left in North America (its studios and transmitter are in Toronto). I would think that, with its 50kW signal, you should hear it quite well after sundown. I don't know how many stations are on or near 740 kHz in your area (I'll look on RadioStationWorld.com after I write this), but if that frequency and nearby ones (700-730 and 750-780) are quiet, you should hear AM 740 just fine. You might have problems with interference from 50kW flamethrowers such as WLW Cincinnati (700), WGN-AM Chicago (720), WSB-AM Atlanta (750), WJR Detroit (760), WABC-AM New York (770) and WBBM-AM Chicago (780), but since your Zenith is very likely quite selective (since it has an RF stage it almost has to be), interference from these stations shouldn't be too much of an issue.
Your radio is probably a variant of Zenith's "Filter-Tenna" wedge-shaped receivers, which as you noted also have RF amp stages ahead of the antennas. I think these receivers were very popular in areas with few or no local AM stations, or areas some distance from big-city stations. The shielded antenna helps a lot as well (especially if you are listening to weak or distant stations), to prevent interference from such things as fluorescent lights, motors, sparks and the like. I believe this type of antenna is a huge improvement (because of the shielding) over Zenith's original "Wavemagnet" loop antenna, mounted on the back covers of their older AM and AM/FM sets. I have a Zenith C845 with a Wavemagnet loop that works very well (I have heard New Orleans' WWL on this radio more than once), but the loop is not shielded, so I get quite a bit of interference between stations from horizontal-oscillator harmonics when my neighbors are watching TV. I was tuning around on AM on my C845 last night, however, and heard a snatch of the Phil Hendrie syndicated talk program over a station about 80 miles from here. The station sounded like it was right next door.
