I would assume that flexible resistors use the same color code as carbon resistors. The only one in the parts list that could match based upon the green stripe is R19 which is 450 ohms. I would think it would have yellow-green-brown stripes. Looking at where it is connected in the circuit would be a better way to determine which one it is. R19 is the cathode resistor for the 6F6 so would connect between pin 8 of the 6F6 and ground. R2 is the cathode resistor for the 6A8 and connects between pin 8 and pin 1 (ground) of the 6A8. R5 is the cathode resistor for the 6K7 and connects between pin 5 (5 is tied to 8) and ground.
Sean - WØKPX
