Old 02-04-2010, 12:20 PM
Old 02-04-2010, 09:34 PM
bradman16 bradman16 is offline
VK Member
Is it one that's driven by a toothed belt from the top of the threading mechanism? If it is, then most front loading Sony's from the time should be similar, or identical.
Which part is broken? The last time I needed to repair one, the part I needed was available without having to replace the whole loading mechanism.
Hi, no, there is no belt, I have other loading mechanisms from other betamax models and they are different, I know the one you are referring to, with the orange belt. This one has a little motor with a spiral shaft which drives most of it, the part that's broken is really broken, it's the frame. I would like to just replace it, if I found the exact one it just screws in, re-wire the motor and I am done. It's just finding the part, I'd buy an otherwise broken machine if I knew the compatibility...I *think* some of the HF models are similar...but I am not sure, that is why I have posted here...what model did you work on? a SL 2300/2400? Thanks...
