If you use a 6AX4 or 6AU4, you may find that you can actually go back to the original filament winding. Since the high pulse voltage won't be present on the later tube type's filaments, no arcing will occur. To Matt... You are correct about the B+ connection to the 6W4 filament in your set. It was to limit the pulse voltage. However, I would strongly recommend replacing your damper tube too with one of the later ones suggested. Those tubes were developed for exactly this reason, and will save lots of heartache down the road. Others that will work and give you the same measure of protection: 6DA4 6DE4 Always do yourself a favor... tap the damper tube when the set is on. If it arcs, change it. It's gonna short. BTW guys... Those tubes are SOOOOOO common you should be able to find as many as you want for a buck apiece. Good luck! |
