Old 01-28-2010, 07:51 PM
MarkWilson MarkWilson is offline
Rca ctc-40 feeler
I have an RCA CTC-40 that needs a horizontal linearity coil (part#126847). Just wondering if anyone has any NOS or parts layin around for grabs. Any info or help would be greatly appreciated.
Old 01-29-2010, 11:59 AM
I have some parts but struck out on that one-email/call Moyer Electronics in PA if you haven't already, good chance they have one.
Old 01-29-2010, 12:31 PM
Findm-Keepm's Avatar
Followin' the Rules...
Looking at my 40, the horizontal lin coil is quite simple - looks to be a single coil of 22 gauge wire wound to the outer diameter of the coil form. If yours is shorted or open, a rewind would be a cinch to do. Radio Shack still sells the magnet wire. 3 pins, only two are used - start and end, that simple.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 01-29-2010, 10:14 PM
Found it at Moyer...they also had a new set of tuning knobs for this set so I picked them up as well as one of mine are missing. How much of a task is it to replace this coil? Would rather do it than haul it away for someone else to do it if its fairly straight forward. I'm no dummy when it comes to soldering n such.
Old 01-29-2010, 10:41 PM
Pretty simple - slide the chassis back, desolder the three pins (they kind of "snap" in to the board) and remove the old coil. Then just solder in the new one. You'll need a hex alignment tool (what I've always called a diddle stick) to adjust the linearity after replacing the coil. Specs on the coil are tight - .3 to 1.2 uH range, which isn't much at the realtively low frequency the coil is operated at.
What specifically was wrong with the old one?
Brian
Old 01-31-2010, 08:58 PM
Its blown apart into two peices. The picture is certainly watchable...however if you get a letterbox program on (almost every channel these days) you can see the picture has a "bowtie" shape to it. This being a combo I hate to drag it all the way to the repair shop for this simple fix as its an hour away. Not to mention the weight of this monster. I have a set of hex tools from when I was adjusting the convergence coils.
Thanks for the info...much appreciated
Old 02-02-2010, 09:35 PM
One other TV question. What would cause me to lose focus when the picture is bright? For instance, I have perfectly crisp clear picture then when I get a screen with loads of white in the background I lose focus until the overall picture comes back to a darker level. Should I look at the brightness limiter? This didn't start until I replaced the HV rectifier tube.
Old 02-02-2010, 11:22 PM
000
Old 02-03-2010, 06:43 AM
Yep sure does....Guess I'll have to find another HV rect tube.
Old 02-03-2010, 12:51 PM
What type do they use? Should be dime-a-dozen. I'm bound to have one NOS.
Old 02-03-2010, 06:56 PM
Not sure without taking the set apart...which I will get to this weekend. Anyone have a schematic on a ctc-40 that they could get me a number for this HV tube? Also, this is a combo, the audio has NO bass response at all.....either on the tv or the stereo. The bass control is working... barely but with solid state, not sure where to start looking, any suggestions were to start would help.
Old 02-03-2010, 10:14 PM
I'm home now so I checked, takes a 3CZ3. Not the most common, but I do have a spare NOS tube. Send a PM with your address if you want it-five bucks should cover everything.
