Old 01-17-2010, 11:44 AM
kx250rider's Avatar
REAL TVs have TUBES!
The AC cord is straight line voltage, and has a slightly rounded plug with the stud on top to push the switch in. You can probably still get that new from Andrews, if you need. You can also try modifying a cord from a laptop or printer power supply... I've seen some of those that are darn close in size & pin spacing. The Sony is wider spacing than a cheater cord, unfortunately.
Don't worry about Variac'ing it up... New enough. Nice set too! I have one. They usually work fine, unless been dropped. If I'm not mistaken, the battery pack is a stack of NiCd 'D' batteries in a sealed case. Beware of leakage!
Charles
