I scoped the G2 voltage and there is minimal ripple. Perhaps a volt. The G2 is +254V. This shouldn't account for the focus problem. Also, since this is derived from the +180V supply, it shouldn't be causing the keystoning either. I can't get to the -125 supply yet to check it, but it could have ripple causing the keystoning.
The gun does not appear to be a slashed field type. It doesn't seem bent either, but I can't see enough of it to be sure either. This is a rebuilt 12LP4 and the gun is different than the original type. If the end is offset like I see in some diagrams, that might be causing the left shift that I'm having with the raster. I've tried centering the focus magnet better and playing with the yoke with minimal improvement. Since the gun is different I started to wonder if I needed to use a single field trap instead. The instructions that came with a Miller adjustable single field trap says that CRTs up to 10" or 12" having a straight gun, generally use a double ion trap of 38 gauss. I think by straight gun they mean one with a slashed field. Then they go on to say that CRTs of 14" to 17" having a bent gun, use a single ion trap of 35 to 45 Gauss. Larger CRTs use a single ion trap of 45 to 55 Gauss. Since it doesn't appear to be a slashed field type I decided to try a single field type. I had to adjust the field down to 35 Gauss for best results. This is the same strength as the double field trap that I have. With it adjusted to the best position I wasn't able to do any better than I did with the double field trap. With both of them I have to butt it up against the base. I get the impression that it might be better to even move it over the base. Perhaps the field is too strong, but I can't adjust the adjustable trap any lower than 35 Gauss. The HV is at 8.8KV. The manual says it should be between 9.5KV to 7.5KV depending on the brightness setting. I heard some corona in the coffee can today so I've got to find that. I've suspected it in the past, but I've never been able to see it. I was also afraid of getting my nose too close. I have another 12LP4 that is rebuilt that I can try. I noticed a strange charging effect when I used the single field trap. I'd adjust it, it would be o.k. for a few seconds and then drift. This didn't happen at the best position though. If it's a matter of not having the slashed field type gun, I have one unrestored set that has a good original 12LP4 in it. I hate to take it out but I may have to eventually try that. John |
