Old 01-12-2010, 07:42 PM
Findm-Keepm's Avatar
Followin' the Rules...
On those Sylvanias, I can offer up this: check the brightness limiter control settings. (R294 on my factory schematic, should be near the service switch)
After that, I'd be looking at voltages - Sylvania marked the boards with the voltage - +/- 10 percent should be good.
There is a video driver transistor that the service switch affects - it's Q214 on my schematic. It feeds all of the RGB output amp transistors. The emitter voltage should vary a bit (~ 15V, varies a volt or so) when the service switch is cycled.
It seems your +200V supply is working, and you have boost, so check the 330K 1W resistor off of the screen controls. Often this will open and cause problems. Power down when checking, because one side will have boost (+1100V) on it if it's open.
I'm working without benefit of my service notes, which I can look at tomorrow. This should get you started though.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
