there are 3 main boards
IF Chroma deflection did the wiggle thing on a bunch of transistors checked the video amp, blanking and some other transistor on the chorma board, all tested good. cycled the service switch several times. I may need to pop for a Sams if no one has one here on the boards. I have no idea what to do next short of checking all the little electro caps. I dont have an esr meter so I would need to take them out of circuit for my old heath tester (I assume the ESR meter does not find a shorted or leaky cap anyway). Are those worth the 150-200$ I see them listed for, or am I just better off pulling the cap and testing in my old heath kit tester? I am assuming I can concentrate on the chroma board since I am pretty sure the vert sweep is working and I have HV so the horz is working, I am getting good sound so I assume the IF board is ok. My next course of action was to trace the brightness control pot wires the the PCB and the G1 grid wires to try to understand high bias is set on the CRT (that is with out a schematic) for now. |
