This is some great info...ive got two clock radios, a zenith and a motorola I need to start fixing up, needs a re-cap, re-resistor.....and im sure the clocks will be noisy
Mark |
I finally looked at this 1957 RCA clock radio I got when I started this thread. I had assumed the clock was like the others I had seen, where the mechanism is sealed, but that wasn't totally the case here, couldn't get it totally apart, but got a cover off and got in there enough to squirt some WD40 in there, which so far has quieted it down.
The radio portion had a corner broken off the circuit board, but I glued it back together with super glue, waited until I was sure it was dry, then just added solder across the one trace that went across the corner, I was going to add a wire in it's place, but it soldered up good, so I left it like that. Other than new caps, the radio just needed a new 50C5 to replace the one in there with an open filament. Now I finally have a good old, quiet clock radio. Last edited by Adam; 05-11-2014 at 08:34 PM. |
I've got that same clock radio... except the clock's face is black i think. Yours is in better condition than mine. Both clock and radio on mine work... but the radio could use a little work.
Charlie Trahan He who dies with the most toys still dies. |
That's a nice looking radio you have there. Very clean. |
The cover you see on the back of the clock pries off, and then you can see some of what's moving in there. I ran it for a couple hours after I got it working, and the clock started to get a little noisy again, then I left it unplugged for a day or so, tried it again, and it was quiet again, but I still left it unplugged. I'm thinking I might try and get some oil in there, rather than just the WD40.
Adam, that radio looks like it was just bought yesterday!
I polished it up with some of that novus #2.
