Old 12-21-2009, 01:33 PM
sgtrob's Avatar
sgtrob sgtrob is offline
AK Member
I did check the service switch, it checked good. The only thing I am curious about, is that the yoke was real loose, like someone took it off, and hastily put it back on. I hope they didn't damage it. Ill check those transistors, too. Thanks for the advice, all of you, as this is strange territory for me.
Old 12-22-2009, 01:04 PM
kx250rider's Avatar
REAL TVs have TUBES!
Originally Posted by sgtrob View Post
Oh ok. Are there any other circuit differences besides the Horizontal ouput? Also anyone out there have a copy of the SAMS? My subscription expired.
I have it on the CTC-47, which should be the same chassis except for the tuner section. PM me if you like, and I can Xerox it for you and mail it. It's the RCA factory manual
Charles
Old 12-22-2009, 02:07 PM
Zenith26kc20's Avatar
If I remember right, the SCR's are high voltage. I remember something about a vertical coupling electrolytic opening up and killing vertical. I'll dig out a sams and take a look. Those were fun sets!
Old 12-22-2009, 02:24 PM
Like Doug said, check the setup switch first.
After that, check for voltage on Q101. It's fed from the 82 volt power supply. There is a 39 ohm, 5 watt resistor that may be open. If it is, suspect Q101. There are 4 other transistors in the vertical. Let me know if you have the collector voltage and I'll go further if need be.
Old 12-23-2009, 03:00 PM
sgtrob's Avatar
AK Member
Thanks for the advice, everyone. Going to tear into the set this weekend, will let you guys know what I find! I like the layout of the chassis, all of the components look well spread out, and easily accessible.
Old 12-25-2009, 10:17 PM
freakaftr8's Avatar
Convergence freak!
Oh.. My bad, I meant transistor. Be sure to check solder connections off the vertical transformer. Especially on the terminal strips.. Guess it could be a lytic too. I know it's a different beast but I had a ctc-17 w/ no vertical deflection, turned out to be a bad connection on the terminal strip. Those ceramic heat resistors put off a crapload of heat and the wire coating seems corrosive when it gets hot.
Old 12-26-2009, 05:53 PM
sgtrob's Avatar
AK Member
ITS ALIVE!!! I found the 3564 Vertical output transistor defective. It cross referenced to an NTE-162, so off to Fry's I went, and found one! The heat sink grease on the old one was completely dried up and flaking off. so, after I swapped out the transistor with new grease, I turned the TV on, and it came to life. All of the controls needed adjustment of some sort, and the tuner needs a good cleaning, but it works. My next order of business on it is to replace the cheesy on-off switch some one rigged in there, in place of the old one. Another thing about this reciever, I was actually amazed at how tiny the flyback transformer was comapred to the other sets.
Old 12-26-2009, 06:23 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Nice job! I've always liked that style of RCA sets with the pull-out control panel drawer. Good to see another one of them alive.
Old 12-26-2009, 07:07 PM
Glad you got it going! The reason that flyback is smaller is because that transformer only puts out about 6 or 7 KV, which is then sent to the quadrupler, where the voltage is ramped up to around 25-28 KV.
Old 12-27-2009, 02:25 AM
freakaftr8's Avatar
Convergence freak!
Way cool! That set looks like it's producing a great picture too!! Well done
Old 12-29-2009, 09:09 PM
Check the setup switch FIRST as it could also be dirty from setting or just plain set in the service position. The 44 was the second SS generation from a CTC40 and was ALL SS to include the HV department. It is a scarce set and certainly worth keeping.
julian
Old 01-05-2010, 09:16 PM
roundscreen roundscreen is offline
That tiny flyback get's vary hot after the set has been on for a couple hours.
I removed the metal cover to the fly cage on my ctc47 and it cool down quite a bit. If you have kids, pets, etc. Make sure you put the back cover on the set before you put it in service.
Also I would check for bad caps and connections in the vertical circuit if the vertical output transistor goes defective again.
Cool set.
