Well here's what I got..
I noticed the horiz lock is still finicky, but at startup, almost like a weak tube, but it straightens out. With the vertical, still no lock.
On the 6KA8 sams points that between pin 1 and pin 8 of the 6GF7 there is a 220k resistor and a .033 10% cap. On pin 1 of the 6KA8 I have 52v and should have 120v. On pin 8 of the 6GF7 I have 300v where I should have 240v. If I put the meter lead on pin 8 to check voltages, vertical locks! Think the meter drops the voltage.
Something else is odd, on the 6KA8 pin 9, I should have 20v and im getting 52v, all other voltages on the circuits are within reason.
