Old 11-28-2009, 11:57 PM
I suspect it was mostly capacitors that killed sets back then, same as now...
Actually at that stage in time, capacitors in TV sets had not aged to the point of epidemic failure as they would 30-40-50 years on. The most common failure was indeed tubes, most frequently the damper, hor.output, and rectifier.. in that order. Filter caps were the most frequent non-tube components to fail. Bill(oc)
