The red has gone from 146 to now 205
The blue has gone from 82 to now 100 On the tube socket pin3 was 281 it is now 240 and pin1 was 275 and is now also 240. I checked the (+) cap to chassis ground it was 251 and now is 276 (+) cap to other side (-) was 271 it is now 291. When I solder pin1 to ground is it to the chassis or somewhere on a terminal strip?? Used cleaner on the control selector..didnt do anything for reception..stayed the same. Signal only comes in with the A,G,S, three wire antenna..by only hooking up the "G" wire. Put them all on proper screws and no signal..? Put just "G" back on alone..Touch it with a screw driver it makes loud crack sound and comes in better when I do that. |
