Old 10-16-2009, 06:08 PM
I just did something you won't believe. I actually did a tube swap in a 25" '98 Zenith with a dead tube (red dead, green almost dead, blue good). I had some fun with the old tube before pulling it out. I cranked the filament voltage up to 12 volts (that's how high I had to go to get it to register "good"). When I did that and checked for shorts, the needle was going crazy on all guns. hitting the neck of the tube with a screwdriver handle was causing even more excitement with the shorts test. I was just about to rip out the chassis when I remembered there was a 25" Magnavox tube from the late '90's in an empty cabinet behind my shop waiting to be thrown out. The mounting ears on the Magnavox tube were a little higher than the ones on the Zenith tube; but, I was able to mount it without any problem. I never could get the purity right and ended up ripping out the rubber yoke wedges and shoving the yoke all the way up on the tube. Actually, the set that the Magnavox tube was in had been dropped; so, there may be some shodowmask damage to the Magnavox tube. At least it's watchable now and maybe I can find it a home. With that Magnavox tube installed, the TV is probably more reliable now than it was the day it left the factory.
