Okay, I've got an oddball part here... a coil wound around a .15 mfd paper cap in the horz circuit just before the HOT. The two are connected in parallel. Haven't really seen this before. Can't just leave it... that .15 is sure to go bad at some point (if it isn't already).
So... how do I go about this??? Tell me what you think.
Charlie Trahan He who dies with the most toys still dies. Last edited by Charlie; 10-04-2009 at 04:23 PM. |
There is an article in the latest issue of Antique Radio Classified(www.antiqueradio.com) about placing a new capacitor inside the shell of an old one. Could this be done? If so, the old shell will keep the coil in it s present form.
I have seen this kind of thing in Philco radios, but not TVs. Also, if you find out what the correct knobs are for the TV, I may have them. I have a box of NOS Motorola TV knobs from that era. |
The SAMs might say something about it. It's fairly easy to restuff the paper caps. You just need to heat it gently with a heat gun or oven until the wax melts and you can then pull out the insides. The wax on the end seems to melt at higher temperature than the wax they dip the whole thing into. John |
