Old 09-28-2009, 01:04 PM
marty59's Avatar
marty59 marty59 is offline
I've been kinda stuck in old school, so this thread's been informative. It sure seems that some areas got the short end of the deal...and if you're rural only worse.
I have cable but I've always had an outdoor antenna for back up and secondary use.
Gone are the days when you could dx for fun with a deceint antenna and a rotor!
Old 09-28-2009, 01:15 PM
Zenith26kc20's Avatar
Gotta say, the good old days are still around. I use two home made (DIY) UHF antennas at a weekend camp and the weekend just past they were picking up 100+ miles away without any appreciable problems. One is a 4 bow tie and the other is a double stacked 6 bay (12 total bow ties). At home I use a channel Master 4251 and a Wade VIP-307. You may look into building a copy of the old Hoverman set top UHF that Radio Shack used to sell. There are pictures on one of the threads here.
Don't expect miracles indoors. UHF has a real problem getting a decent signal into a house.
Also, the converter box makes a lot of difference. I use the Insignia and Digital Stream. The Coby and Apex need a great deal more signal to decode. There is a four bay DIY shown on the internet and it's easy to make. It may perform well enough indoors for you. If you put it outside I would recommend painting the center to protect it from the elements. Keep us posted!
Old 09-28-2009, 05:38 PM
peverett peverett is offline
My best DTV reception has also been with the Digital Stream models. The added advantage to these is that the do not seem to run hot, so may last longer.
Old 09-28-2009, 07:54 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
NOT gone, just transformed.
DTV DX is harder than analog was, since a DTV signal has to "rule its channel" if it is to be identified at all. Still, I've seen two DTVs by Es and have received tropo of UHF DTV as far as 400 miles (no snow, no ghosting, and -instant- ID of the DX in most cases).
Analog DX has entered a brave new world. Many times, skip would come in from the SSW, and WBRZ from Baton Rouge would be fighting it out with local WJBK Detroit (both channel 2). This July, I had Es to the SSW. WBRZ and WJBK are gone, so I saw YNFA302 instead - from Managua, Nicaragua.
