Old 09-25-2009, 10:02 PM
damen's Avatar
damen damen is offline
Thanks for your help on this guys. Here is a scan of the sams my scanner is to small to do a full shot. The more I have looked at it I to think it just don't show the exact same set up as mine the picture is so poor and faded it is hard to tell and the schematic seem to show one side of that diode going to ground and the other to a VDR and that is not the case on my chassis. Whats bad is when I got the set I replaced the resistor with a 100 ohm resistor and can't find the one I pulled it looked like that was what it was but being burnt I could have been wrong. The set does work well and has a good picture but the flyback seems to be running a little hot quite a bit hotter than my CTC 7 set so I just want to be sure that is the rite resistor. That resistor has a wire on the diode side that goes to the pin 9 of the shunt regulator and the other side is going to a 8.2 m ohm resistor to pin2 of the HOT and yes the 220k resistor on the white band side of the diode is going to the color killer.
