Old 09-25-2009, 12:17 AM
ha1156w's Avatar
ha1156w ha1156w is offline
I can concur with the earlier opinion about the transistors. I have repaired about a half dozen of these in the past two years for a local antique shop, and all of them had dead/weak transistors in either the preamp or the FM tuner. The best check is to plug something into the AUX inputs (on the chassis itself behind the tuner dial) and see if the amplifier sections work first. Get the power and pre-amps verified, then move on to the FM tuner. I've seen three with bad mixer/rf amp transistors. All the transistors in the FM have the same germanium cross, so you can mix and match a new one till you find the one(s) that are bad.
