Not from running a cable but it might be the HV anode lead on the CRT. Being in the basement, it's possible for the moisture in the air to affect the connection. Discharge the HV with a probe or high watt resistor to ground, be careful as it can be a nasty shock. Then clean the anode with rubbing alcohol, put some di-electric silicone on the cup and reconnect. I bet that's the noise. Since you say it changes with volume, that part is a head scratcher. Are you sure it's coming from the speaker?
