Old 09-21-2009, 01:25 PM
Zenith26kc20's Avatar
I didn't replace the can electrolytic on the one here. It ESR'd OK. Germanium transistors are inherently noisier than silicon. If both channels are hissing the same I would say "close enough" I will say the transistor should be replaced with the same or equivalent to make sure current capability is adequate. Some RF and IF transistors are not able to last as driver and AF amp. I had to touch up the multiplex chassis alignment just slightly. Be careful and don't force a stuck slug to turn. If a reasonable amount of force doesn't free it up leave it. The coils break easily.
