To start, you can do a few quick checks without the manual: Check the fuses; a glass pigtail (soldered-in) 1.25 or 1.5 amp fuse, and a 4 amp or 5 amp fuse (same type). One is likely blown, and that's due to a short in either the horizontal circuit, or the power supply module. I'm a bit foggy on the physical layout of that set, but if I recall, the power supply is mainly squeezed in a cage below the CRT neck, and between the two hinged swing-out boards. Find the horizontal output, (should be a T03 case on a fairly big heat sink), and it should say H OUT on the heatsink. Also check the little green ceramic disk, which goes from collector (to emitter, I think). That can short and burn. Usually you can see a black hole in it, if it did, and it will measure shorted when disconnected. If that set has the horizontal output mounted off the board, follow the leads to the sweep board, and the horizontal drive transformer should be right there. Often there are cracked solder joints at that transformer. It's location # T401 in a lot of Sonys. Also, that set may have a high voltage divider block, which is mounted up on the metal X-ray shield of the CRT. Those go bad too, and load down the power supply. However, usually they won't blow the fuse. They just knock the set into shutdown, and you hear a squeal. An equally common possiblity of a cause of a short/blown fuse, is the flyback. Sadly, I have to say it's a strong possiblity, especially if the other things check out OK. One more remote possiblity, is that if the AC line fuse is blown, check the degaussing thermistor. Those can either short or get bad solder connections, causing the line fuse to blow. Follow the degaussing coil leads from the rim of the CRT shield to the board, and look for a 1/2" black cube with 3 legs on the board, right where that degaussing coil plugs in. Naturally, there are all kinds of other causes for power supply problems, but the above is what I've seen most on 80s Sonys, including that 25XBR. Charles
Collecting & restoring TVs in Los Angeles since age 10 |
