Old 08-11-2009, 09:27 AM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
Blu-ray and HDTV are fantastic technologies, and antique-TV collecting and restoration is fun too, but I don't see a value to attempting to mix them together. This analog shut-off thing will not have any effect on our hobby whatsoever.
I guess some of us see a different point of view on mixing the old tech with the new. Blue ray is just a recording format and with the right computer software and graphics card you can easily drive an antique TV set. It's not expecnsive to do since computers are cheap and so are display cards ...maybe the trick is knowing that you can do it? Anyways, I do and have alot of fun with it. The results are quite spectacular!
Old 08-11-2009, 10:02 AM
000
Old 08-12-2009, 03:35 AM
Originally Posted by Tom_Ryan View Post
I guess some of us see a different point of view on mixing the old tech with the new. Blue ray is just a recording format and with the right computer software and graphics card you can easily drive an antique TV set. It's not expensive to do since computers are cheap and so are display cards ...maybe the trick is knowing that you can do it? Anyways, I do and have a lot of fun with it. The results are quite spectacular!
I built my first home-theater computer in 2000, with one of the first fifty HDTV recording boards sold to the public (HiPix DTV-200), and I do all of my TV watching and recording with Windows Media Center (now using MC7), so I am aware of the benefits of such equipment. It seems like overkill for feeding old NTSC TV sets, but it is indeed possible as you said.
Old 08-12-2009, 09:02 AM
Tom_Ryan's Avatar
That's my point, you won't me able to do it without using illegal software, or hardware. No legally licensed blu-ray playback system will output any kind of analog signal in 4 years, and there's no legal way to convert HDMI into any analog format. Yes, it can be done, but it requires expensive illegal items that can be disabled if the blue ray people figure out a way of doing it.
I'm sure regular DVD will be around for a while longer, but the movie industry definitely wants to replace DVD with Blu-ray. If you think it can't happen, then try finding a recent movie on VHS. It's only used for HD right now, but it does support SD, and I can see them selling entire "box sets" on a single blu-ray disc. Also, those of us with HDTVs would be forced to buy second copies of things on DVD if we want to use them on TVs without HDMI.
No, you misunderstood. How to do it means...In a Blue ray licensed system, the BD playback device is installed on a computer running licensed software, in my case Microsoft Windows Media Center software (WinXP Media Center or Vista) with an approved graphics card supporting Radeon or NVIDIA chip sets. The graphics cards automatically default to analog if an HDMI capable display device is not detected. One suggestion is to use 2 separate graphics cards - one to drive HDMI equipped display devices and the other to drive non-HDMI devices that need analog signals such as an old NTSC TV set.
I agree. I suppose it's all relative, for example in it's day the thought of broadcasting color when all you wanted was b&w was considered by many as overkill too. Those with enough savy technical ability knew both were possible. I also suppose the same mantra exists in our digital age today. At least it's comforting to know that the wang fangled new computers available can still create NTSC signals to drive these old TVs.
Old 08-12-2009, 10:34 PM
000
Old 08-12-2009, 10:41 PM
jayk's Avatar
jayk jayk is offline
<Akai GX-630D-SS
ITC, something to consider.
Old 08-12-2009, 11:26 PM
Out with the old, in with the new....whether we like it or not
This is exactly why I think analog video in any form, be it HDTV or standard DVD (new releases only, not existing discs), is on its way out. The motion picture companies will likely support the addition of a flag on new Blu-ray discs (eventually) that will disable analog video outputs of standard DVD players, making these discs unwatchable on anything other than Blu-ray players....and it will be some time before the latter are anywhere near as cheap as DVD players are today.
By degrees, we are being brought into the digital age, whether we like it or not. First it was digital TV, now it is Blu-ray threatening to edge out standard DVDs. (I plan to stock up on as many of my favorite shows on DVD as I can as long as they are available, for just this reason.) I can't help wondering what may be next. The DTV converter boxes are designed to last only a short time before they burn up or otherwise quit because they are meant to be a stopgap measure, to allow folks to use their old analog TVs until the sets go belly-up; this is probably also why the government's DTV converter-box coupon program ended when it did, the last day of last month.
I can see a day coming, maybe not next week, next month or even next year (!), but eventually, when the only TV receivers we will see in American (and eventually Canadian) homes will be flat-panel TVs. (Since 2007, it has been unlawful for any store or retail chain to sell new-in-box analog NTSC televisions unless the sets come with a clearly-worded warning that they will not work on an antenna after 06.12.09, and must be connected to cable/satellite or a to a converter box if they are to be used after that date.)
The government cannot declare analog sets illegal, but these sets will not work with antennas without modification, so the public had better get used to the idea that the sun is indeed setting on analog television in North America. The average person does not understand why his or her TV will not work anymore (for the most part, unless the person is in an area with LPTV [low-power TV] stations or translators) when connected directly to an antenna, but whether they understand it or not, that day is here as of 06.12, and there will be no turning back. Full-power television stations in the US are already 100-percent digital, and Canada's stations will follow suit in 2012 or 2013, so the message to all television viewers anywhere in North America, whether they understand the technical details of it or not, is or should be very clear: Go digital or go without television.
Old 08-12-2009, 11:37 PM
jayk's Avatar
<Akai GX-630D-SS
hey, we're americans, we're fat, we're obese (so they say), and worst of all, we're complacent.
we wait til a situation gets too far out of hand before we think we should do something about it.
so many may go without tv for while.
probably the best thing that could ever happen to them/us.
just my $.02
Old 08-13-2009, 12:19 AM
That is already the case, Blu discs WON'T play on a standard DVD player, just like Beta tapes won't play in a VHS machine, completely different format.
Old 08-14-2009, 12:33 AM
Tom_Ryan's Avatar
Big business and Government the real winners of the digital TV!
... The government cannot declare analog sets illegal, ....
Are you sure about that? Radar detectors are illegal to use (possibly own) in some States ...perhaps because speeding can harm someone if there's an accident? While I can't imagine harming someone by simply watching an old analog TV set? ...please correct me, I could be wrong ...it might offend some politician if they can't be seen in the glory of 1080p which is completely counter intutive to Governments generally thought to be slow, prone to error, lacking resolution, grey area policies or taking a black & white stand on most issues. I still remember when I was a wee tyke my Dad's Philco 41 radio had a label on the back of it stating that it was unlawful to operate without a license. Apparently that law fizzled. Still have the radio packed away somewhere. In any event, I'm sure I won't vote for anyone that raises taxes or abolishes the ownership of analog TV sets or there use! Nay, not me.
Keep in mind, we live in an age where the Government tried but failed to keep out of the public domain some of the strongest and most durable public key ciphers to protect data introduced by the computer industry. So, I think the whole argument of the demise of analog, while very real, is being driven by big business and greedy Governments looking for ways to collect tax. The wireless industry in America is partly responsible for driving the FCC to consolidate spectrum which generates billions of dollars in Government revenue. Digital TV is more spectrum efficient compared to analog broadcast standards - that means more stations per MHz and more taxes. It's all about money. It's not about mom and dad needing higher resoltuion of anything. Even an old GE Portacolor is good enough for me! Regardless of the outcome, collectors of old TV sets will likely still be able to enjoy their use. Ganted it may be more inconvenience becuase of required convertor boxes or agile modulators to generate the necessary RF signals. Hey, then again ....this can be also be a technical hobby, right?
