Old 08-04-2009, 12:31 PM
Originally Posted by zenithfan1 View Post
Not to veer off topic but that light might just be your oxygen sensor, hopefully.
Wouldn't surprise me, I've had it replaced twice over the years (i'ts 14+ yo). Not cheap to replace and I'll fail the emission test next time if I don't get it fixed.
I'll bring it over to my local guy - he has the gizmo to read the OBD codes.
Old 08-04-2009, 03:10 PM
miniman82's Avatar
First Light: 1952-2011
IL has 2 emissions tests: OBD, and tailpipe. If your car is older than 1996 vintage, it will be a tailpipe test which is single speed (idle). The O2 sensor on most cars doesn't do anything until you're at cruising speed anyway, so if it's bad your idle shouldn't be affected and you should pass.
Old 08-04-2009, 03:23 PM
My car was the 1st gen to have OBD and a bad O2 sensor is automatic failure. I've been through that twice
Old 08-04-2009, 03:46 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
Originally Posted by David Roper View Post
BUT . . . the coolest thing I see is the RCA ribbon mic
Those have become quite valuable and sound wonderful. Note the ribbons are quite fragile, so whatever you do, don't blow into one!
