Old 07-31-2009, 11:03 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Originally Posted by Dan Schafer View Post
In short Can I photo the VCR and have someone ID the parts I need to look at. Not sure what1/2 load arm is audio, control track or RVS thread. I'm tired and I wrote a nice detailed reply that took time. What happened? Very annoyed!
That's what you need to do so I or someone else can point to the loading arm that's likely the culprit. Must say though I've seen some stuck onto the shaft so hard only way I could get loose to take apart was heat the arm with the tip of a soldering iron until it would move. You will need to align the arm height by adjusting the nut once you clean, lube and put back together, or else some tape damage could result. Before you loosen the nut, be sure to take a mental note of how close to the top of the threaded part of the pivot shaft is above the nut. It's probably sticking up barely above the top of the nut and you can feel that with your fingernail. There will be a little black washer under the nut too, don't lose that. Good luck.
(BTW I've NEVER had it log me out.)
