I can't remember if its on the chassis or convergence board. - but there is one.
It will either be a pot with a plastic philips insert or a hex slug. The adjustment is a little quirky, and if adjusted incorrectly will make the set appear to have a shorted turn (vertical trapezoid) Make small adjustments will looking at the top and bottom on a crosshatch. You should be able to dial it in well enough that it looks correct at 4 feet or further.
Jordan |
