Old 02-25-2005, 10:39 AM
ha1156w's Avatar
ha1156w ha1156w is offline
Although I can't say for sure what the issue would be having never seen this particular model, my first stab at it would be to check for dry solder joints and perhaps the electrolytic capacitors next. It's definately a stability problem in the tuner. The higher in frequency it goes, the less stable it gets. This can also be caused by contacts on any plug-in components/boards that get dirty. Is it one of those 12-preset tuners that CM loved so much in the late 70's/early 80's or is it a 10-key calculator-type channel entry? If it's the 12-preset variety, check the varactor knobs on each channel (behind a hidden door). Just like the early VCRs, you have to twiddle the knobs for each and every channel....I was so happy to see that technology die!
HA1156W
